Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
ssargent
Oct 28, 2016Aspirant
Am I understanding this correctly? In order to install the A6210 I just bought, I have to figure out how to go back to an earlier version of Windows 10? That can't be right; it would make more sense to take it back to the store and get a different product.
I've tried it on the desktop for which I bought it and also on my laptop. I can't see any LED light either way and am not sure even where it is.
- JamesGLNov 03, 2016NETGEAR Employee Retired
Hi All,
PM me your contact info if you have issues with A6210 after the Windows 10 anniversary update.
JamesGL
Community Team
- regalNov 05, 2016Aspirant
Hello James My A6210 was working until the update I tried to do. Now won't detect adapter Using Windows 10 latest version.
Help?
- IlovegamimgNov 05, 2016Aspirant
Hey man, ive had the same problem and i fixed it by downgrading windows 10 update. Since they removed the downgrade button u need to downgrade to your first Operating system or just wait. Netgear is taking a long time to fix the problem.
- ssargentNov 08, 2016Aspirant
I returned the A6210 AC1200 adapter to the store and got a Netgear EX6100 N750 extender instead. That solved the problem for which I had bought the adapter, which was the inability to connect to the router from a few rooms away.
