Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
JamesGL
Nov 03, 2016NETGEAR Employee Retired
Hi All,
PM me your contact info if you have issues with A6210 after the Windows 10 anniversary update.
JamesGL
Community Team
regal
Nov 05, 2016Aspirant
Hello James My A6210 was working until the update I tried to do. Now won't detect adapter Using Windows 10 latest version.
Help?
- IlovegamimgNov 05, 2016Aspirant
Hey man, ive had the same problem and i fixed it by downgrading windows 10 update. Since they removed the downgrade button u need to downgrade to your first Operating system or just wait. Netgear is taking a long time to fix the problem.
