Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
regal
Nov 05, 2016Aspirant
Hello James My A6210 was working until the update I tried to do. Now won't detect adapter Using Windows 10 latest version.
Help?
Ilovegamimg
Hey man, ive had the same problem and i fixed it by downgrading windows 10 update. Since they removed the downgrade button u need to downgrade to your first Operating system or just wait. Netgear is taking a long time to fix the problem.
