Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
Catt62
Nov 06, 2016Tutor
Same thing happened to me and on the advice of support I threw away an older model because they said it no longer was working ... so I spent good money on a new one that does not work and trashed a perfectly good one... thanks netgear for wasting my time and money!
Catt62
Nov 06, 2016Tutor
As far as the roll back option goes if Netgear had said this in the begining I could have saved hours upon hours of time and money, but now it is past 10 days and too late!
