Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
koidave
Nov 04, 2016Star
I bought this today as it got good reviews on Amazon. I plugged it in and got the same message as a lot of people onhere, 'Not detected' when the software asks you to plug in the adapter.
I spoke to live chat and they said reverty back to the previous version iof windows before the anniversary update. I can't as its over 10 days since i updated.
They basically said to me, our developers are working on a fix. So in short I have a new £25 brick / doorstop until a fix is worked out. Surely between Microsoft and Netgear this can be worked out. How long do I have to wait for a software fix or do i just send it back for a refund and buy another make of adapter that works as promised.
koidave
Nov 06, 2016Star
Ok, I seem to have solved for my machine and wanted to see if it helped other on here with this adapter.
1.
