Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
ssargent
Oct 28, 2016Aspirant
Am I understanding this correctly? In order to install the A6210 I just bought, I have to figure out how to go back to an earlier version of Windows 10? That can't be right; it would make more sense to take it back to the store and get a different product.
I've tried it on the desktop for which I bought it and also on my laptop. I can't see any LED light either way and am not sure even where it is.
ssargent
Nov 08, 2016Aspirant
I returned the A6210 AC1200 adapter to the store and got a Netgear EX6100 N750 extender instead. That solved the problem for which I had bought the adapter, which was the inability to connect to the router from a few rooms away.
