Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
koidave
Nov 13, 2016Star
Hi, glad you got it working. It's a great powerful adapter, just shocking software and instructions.
- Glenn1951Nov 13, 2016Apprentice
See my post below yours to terrimaree! How simple if they copied "your solution" verbatim to their download page! One heck of a lot of headaches over this would vanish!
