Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
koidave
Nov 13, 2016Star
Hi, glad you got it working. It's a great powerful adapter, just shocking software and instructions.
Glenn1951
Nov 13, 2016Apprentice
See my post below yours to terrimaree! How simple if they copied "your solution" verbatim to their download page! One heck of a lot of headaches over this would vanish!
