Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
koidave
Nov 06, 2016Star
Ok, I seem to have solved for my machine and wanted to see if it helped others on here with this adapter.
1. Run the file: A6210_v1.0.0.35 and as usual wait for the 'Plug in your adapter' message.
2. When you get the 'Adapter not detected', click Cancel
3. Leave the adapter plugged in, do not remove it and go to Device Manager.
4. Under Network adapters you will see: 802.11ac Wireless LAN Card
5. Double click on this and goto the Driver Tab.
6. Click on 'Update Driver'
7. Now choose 'Browse My computer for Driver Software'
8. Now click, 'Let me choose from a list of device drivers on my computer'
9. Choose Netgear A6210 Wifi usb 3.0 adapter and click Next. The driver will be installed
10. Close down device manager.
11. Go to your wifi / internet iceon in the bottom right of your screen. If you are wired, change this to wireless and then connect to your network.
12. The adapter should now be working
13. I then went to here: http://www.netgear.co.uk/home/discover/apps/genie.aspx?cid=wmt_netgear_organic and downloaded the genie software independently of the A6210 software and installed it.
14. It actually worked and now runs ok under Windows 10 with anniversary. Its a pain, I know, but until Netgear sort themsleves out it works, and to be honest the adapter itself is very good and when connected to my virgin Superhub 2 I'm getting 140mbs download. compared to 10 over my very old powerline adapters.
Hope this helps someone.
Thanks
Catt62
Nov 13, 2016Tutor
Glad you all got yours working I tried this solution again today and still got nothing the adapter is listed but only the 2.4 connections show up as available.
- Glenn1951Nov 13, 2016Apprentice
First let me state that I'm NO geek, guru, or IT specialist!
First off the 2.4GHz and 5GHZ are refering to your routers transmit frequency(s)/ protocols (see below) and the A6210's duel band, receiving frequency(s)/ protocols. Did a little test and there is a big difference in speeds!! Wow, I was surprised to say the least!
On the 5GHZ band my download speeds averaged approx. 172 Mbps and up loads around 12 Mbps. Using the 2.4 GHZ connection averaged around 70 Mbps down and 12 Mbps up. the uploads were about the same. Downloads were where the BIG, BIG difference came in. Needless to say I reverted back to the 5GHz band!
On their spec page I also noticed the following protocols for the different frequencies:
- IEEE® 802.11 b/g/n 2.4GHz
- IEEE 802.11 a/n/ac 5.0GHz
You'll have to see what your device manger shows for your setup.
Does your router, either your own personal or what you're leasing/ renting from your provider support 5GHz?? My router from Comcast supports both! If your router only has 2.4 GHz capabilities then that is all you'll see unless you can tap into your neighbors! LOL!
When I right click on my wifi icon (task bar) and it opens, it shows 2 addresses/ names for my home router setup. One is the router name plus 2.4, the other is router name plus 5. Click on it maybe, if your router supports 5 GHZ maybe you can select to connect to the 5GHz! They are exactly the same name except for the 2.4 or 5. "IF" it does support 5 GHz maybe click the network adapter in Device Manager and tell it to update the driver!
Also note their disclaimer copied from their web page:
Maximum wireless signal rate derived from IEEE standard 802.11 specifications. Actual data throughput and wireless coverage will vary. Network conditions and environmental factors, including volume of network tra°c, building materials and construction, and network overhead, lower actual data throughput rate and wireless coverage. NETGEAR makes no express or implied representations or warranties about this product’s compatibility with any future standards.
Like I stated I'm no geek nor am I the moderator who seems to be missing in action here of late!! I hope this helps as it is the best I can do. I tried! Sorry if I wasn't any help. If your router is only capable of the 2.4 GHZ band then that is what you're stuck with.
