Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
koidave
Nov 14, 2016Star
Let's call it a joint effort. Maybe we apply to work as a solutions team for net gear. ...đ
- Glenn1951Nov 15, 2016Apprentice
Might as well as it seems nobody else seems to care!! Where's the moderator?? Where's the programing team??? Hello? (crickets). Well, we'll help if "WE" can. Man, talk about a P.T. Barnum experience!!
I went back up to the top and this forum/ discussion is STILL under the blanket heading of "SOLVED"! What the hey?? "IF" it's solved "what are there still people posting"????
That's why nothing is being done! They think it's over, done, solved! What a boat load of moron!
- pdtommyNov 30, 2016Star
Well after my son spending 2-3 hrs and myself the same time yesterday trying to get this damn thing working, fingers crossed your solution will do the trick. I did the standalone download about 15 times and it eventually detected it completed the download installed and then dropped out. Everytime I rebooted the computer it would be detected for a very short time and then drop out.
Fingers crossed for tonight.
Thanks in advance.
- pdtommyDec 01, 2016Star
You ripper, success thanks guys. It took two attempts but got there in the end. About 10mins after connected an upgrade actually popped up, so installed and still works.
Thanks Guys
