Ilovegamimg
Oct 09, 2016Aspirant
A6210 not being detected and no led light
Hello! I have a problem with my wifi adapter and id like a solution, basically when i had my netgear upgrade my thing didnt work anymore it was not detected, i tried it on my brothers computer and it...
- Oct 18, 2016
I did try it, and it didnt work in his computer also.
but i already have the solution, seems like it doesnt work om the newest windows 10 update so i u installed that newest update and i did go back to the older versions of windows 10 and it works perfect.
terrimaree
Dec 06, 2016Tutor
I think if we want Netgear Support, we need to use support directly and bypass the forums, but sometimes that's such a pain because they ask you tons of things even already been through. Maybe we should all contact them and tell them the problem...and what works. Tell them to fix their issue with the install....
