aitchie
May 23, 2017Aspirant
A6210 Software installation
Good Day 1. How much space (Bytes) does the software for this device require to be installed? 2. Must it be installed on the C:\ Drive, or can it be installed on another logical drive on the ...
- Jun 06, 2017
For future users, the answers to my queations ( which I established myself through trial & error) are:
1. Netgear requires 16.6 MB (17 469 440 bytes) on the hard drive.
2. Netgear does not give the option to be installed on any but the C:\ Drive. It can be installed on another logical drive by moving all the files to that drive, then editing the registry - NOT for the faint-hearted.
Aitchie.
VE6CGX
May 23, 2017Master
Answer 1: If it run out of space, it'll tell.
Answer 2: Any where you want.
Just don't plug it in until asked by the install. wizard.
Good luck.
aitchie
Thanks VE6CGX. I don't have a lot of space left on my C:\ Drive, that's why I asked how many bytes the installation uses.
Aitchie.
- JamesGLMay 29, 2017NETGEAR Employee Retired
Hi aitchie,
I think it is the same MB as the driver. 40-50Mbps will do.
- JamesGLJun 04, 2017NETGEAR Employee Retired
Hi aitchie,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- aitchieJun 06, 2017Aspirant
Aitchie.
