mrsqueezy
Apr 16, 2017Aspirant
A6210 Software Version 1.0.0.36 Disconnections
Hi Again So I've updated Windows and decided to try .36 after the disaster that was .35 Good news the driver solved all the issues that I had with .35 Bad news is that I keep having is...
mackel95
Apr 18, 2017Initiate
Hi,
Not sure if I have the same problem as you but I get disconnected about 30min-1 hours after I've turned my computer on. The A6210 goes into some "installing"-mode and I lose internet during this period. Do you have the same?
mrsqueezy
Apr 18, 2017Aspirant
Hi,
The dropouts appeared to be random
I could have long sessions connected then sudden disconnects
I've also had issues where I've just turned on the PC
