mrsqueezy
Apr 16, 2017Aspirant
A6210 Software Version 1.0.0.36 Disconnections
Hi Again So I've updated Windows and decided to try .36 after the disaster that was .35 Good news the driver solved all the issues that I had with .35 Bad news is that I keep having is...
VE6CGX
Apr 18, 2017Master
Sure bet of updating to new driver is after all traces of older driver is removed(deleted) using control panel 'programs & features'
mrsqueezy
Apr 18, 2017Aspirant
Hi,
I'm not 100% on your statement.
"Sure bet of updating to new driver is after all traces of older driver is removed(deleted) using control panel 'programs & features'"
I fully removed all traces of .35 shortly after they released it (via control panel I believe but it was a long time ago).
I have been using Windows own driver up until I installed creators update where I tried v.36
- I am now accessing the internet using Windows 10 built in driver
- JamesGLApr 23, 2017NETGEAR Employee Retired
Hi All,
Try installing the standalone driver for A6210.
- updatedriversApr 23, 2017Aspirant
Hello James.
I have uninstalled and reinstalled the standalone drivers, but I have gotten the following info from Windows Network Diagnostics:
Issues found
Problem with wireless adapter or access pointProblem with wireless adapter or access point Fixed Fixed
Reset the wireless adapter Completed
Investigate router or access point issues Not run
Issues found Detection details
6 Problem with wireless adapter or access point Fixed Fixed
InformationalNetwork Diagnostics Log
File Name: 1C1654CF-41A4-4912-9B36-A902F61A6703.Repair.1.etl
If you're connected to a hotspot or domain network, contact the network administrator. Otherwise: 1. Unplug or turn off the device. 2. After all the lights on the device are off, wait at least 10 seconds. 3. Turn the device back on or plug it back into the power outlet. To restart a router or access point that has a built-in battery, press and quickly release the Reset button.
Detection details Expand
InformationalDiagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter Wi-Fi driver information:
Description . . . . . . . . . . : NETGEAR A6210 WiFi USB3.0 Adapter
Manufacturer . . . . . . . . . : MediaTek, Inc.
Provider . . . . . . . . . . . : MediaTek, Inc.
Version . . . . . . . . . . . : 5.1.22.0
Inf File Name . . . . . . . . . : C:\WINDOWS\INF\netr28ux.inf
Inf File Date . . . . . . . . . : Saturday, March 18, 2017 8:56:23 PM
Section Name . . . . . . . . . : OS61_RTWLANR_7662_C3.ndi
Hardware ID . . . . . . . . . . : usb\vid_0846&pid_9053
Instance Status Flags . . . . . : 0x180600a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9I also noticed that it is showing an older driver version of "5.1.22.0" and I'm guessing it might be the MediaTek driver that is possibly preinstalled in Windows 10 but I am not certain.
- JamesGLApr 25, 2017NETGEAR Employee Retired
Hi updatedrivers,
Can you remove the NETGEAR folder under program files. Check the programs as well make sure to uninstall any NETGEAR app.
