defh56's avatar
defh56
Follower
Jan 11, 2017
A6210 wifi adapter - Channel Master DVR+ does not aknowledge that it's plugged in.
I'm trying to connect a Channel Master DVR+ to my network with the A6210 Adapter. The A6210 worked in my laptop, but the Channel Master doesn't even aknowledge that it's plugged in to the port. Any thoughts? I am contacting Channel Master also. Thanks
  • Hi defh56,
    The adapter supports Windows based computer and is not compatible with other devices. If your Channel Master DVR has ethernet port, try checking the WNCE2001, WNCE3001 and WNCE4004.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi defh56,
  • JamesGL's avatar
    JamesGL
    Hi defh56,
    We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
