cyntrix
Aug 01, 2016Follower
A6210 Wifi Adapter and Windows 10 Problems
I've gone through this forum, and plenty of others for the last few hours, trying every solution proposed to fix what I can't wrap my head around. I updated my computer to Windows 10 from 8.1, wh...
NJDoug
Aug 01, 2016Guide
This is a known problum that Netgear can not figure out ..... There driver is an Old one from 4/21/2015 before the windows updates .....They have NOT made a new driver AT ALL for this device....... Driver Version 5.1.22.0 .... I have been going around and around for 2 months with the Level 2 suport on this .... And JameGL all the fix's you ty to have customers do will not solve this issue... The device keeps loading a 32 bit driver on a 64 bit system also .... Netgear needs to update the driver as a company like Alpha has that runs the same same chipset ....
JamesGL
Aug 04, 2016NETGEAR Employee Retired
Hi cyntrix,
1. When you plug the adapter on the computer, can you see it under device manager?
2. Do you still get the error 1605?
JamesGL
Community Team
- NJDougAug 07, 2016Guide
JamesGL ...... Have netgear adres this --- driver is an Old one from 4/21/2015 before the windows updates--- and this will solve peoples isssue's ..... This is were the issue is ........
BugCheck 133, {0, 501, 500, 0} *** WARNING: Unable to verify timestamp for A6210.sys *** ERROR: Module load completed but symbols could not be loaded for A6210.sys Probably caused by : A6210.sys ( A6210+109f2 )
