cyntrix
Aug 01, 2016Follower
A6210 Wifi Adapter and Windows 10 Problems
I've gone through this forum, and plenty of others for the last few hours, trying every solution proposed to fix what I can't wrap my head around. I updated my computer to Windows 10 from 8.1, wh...
JamesGL
Aug 04, 2016NETGEAR Employee Retired
Hi cyntrix,
1. When you plug the adapter on the computer, can you see it under device manager?
2. Do you still get the error 1605?
JamesGL
Community Team
NJDoug
Aug 07, 2016Guide
JamesGL ...... Have netgear adres this --- driver is an Old one from 4/21/2015 before the windows updates--- and this will solve peoples isssue's ..... This is were the issue is ........
BugCheck 133, {0, 501, 500, 0}
*** WARNING: Unable to verify timestamp for A6210.sys
*** ERROR: Module load completed but symbols could not be loaded for A6210.sys
Probably caused by : A6210.sys ( A6210+109f2 )
