SmallFry
Mar 14, 2022Follower
A6210 Wifi Adapter causing BSoD
Hello, recently I've started to encounter blue screens when using my wifi adapter, and seemingly only on certain wifi networks. This started to happen when my apartment upgraded the wifi to wifi 6e a...
michaelkenward
Mar 15, 2022Guru - Experienced User
I wonder if it could be related to this:
Solved: A6210 Adapter doesn't auto connect - NETGEAR Communities
then:
SOLVED: Constant Disconnection of Netgear A6210 Ad... - NETGEAR Communities
Different symptoms, but might be worth trying the same solution.
For other ideas, did you try this?
