Mekroval
Jan 26, 2020Follower
SOLVED: Constant Disconnection of Netgear A6210 Adapter
I wanted to share a solution to a reoccuring problem with my A6210 Wifi Adapter that seemed to be causing a problem for a lot of other people as well. Many of the threads on this support community offered solutions that worked for some, but none of them worked for me. I was almost at the point where I was going to junk my A6210, and find a different WiFi adapter.
I'm running a Windows 10 operating system on a Lenovo ThinkCentre M900 (tower) with Intel Core i7-6700. The adapter is used to connect to my Netgear AC1750 Smart WiFi Router, Model R6400.
The problem I was having was that the adapter would intermittently disconnect. At first it only happened once or twice a week, then as time went on at least once a day. About a week ago, the problem became so severe that my adapter was disconnecting continuously. It would stay connected only for a few seconds before disconnecting, then reconnecting, failing, and so forth in an unbreaking cycle.
Most of the threads on this site discussing this issue always refer to this link as solving the problem: https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnects
The problem for me was that this solution didn't work at all. I updated my Netgear router's firmware, And I also updated the latest drivers for the A6210 adapter. But nothing worked. The third recommendation on that link ("Try disabling the Minimum Power consumption feature on the adapter") didn't apply, because that option did NOT appear under the Adapter Properties list.
After exhausting the Netgear forums and other sites, I couldn't figure out what else to do. But it occurred to me that the problem might be related to the USB connection. My A6210 is connected to a USB 3.0 port, and the sound that the OS would make each time the adapter lost the WiFi connection was similar to a USB being removed.
SOLUTION: Based on the above clue, I followed the instructions for the third option mentioned earlier, with one critical difference: I changed the Max USB Speed value from "USB Auto" to "USB 3.0" This INSTANTLY fixed the problem. The adapter immediately found the Wifi signal, and the neverending "connect / disconnect" cycle went away. If you are using the A6210 Adapter on a USB 3.0 port, and experiencing this problem, I would give this a try.
I suspect what was happening was that the A6210 and the operating system were not agreeing on which USB speed to use. The adapter was set to auto-adjust to the proper USB connection, and Win10 was similarly trying to negotiate with the device. However, for some reason they got caught in a logical loop wherer neither the OS nor the adapter could actually agree -- hence the inability for the adapter to stay mounted for more than a second or two. .I'm speculating here, but this is the only solution I've found to this problem.
I hope this helps some poor soul that was as stuck as I was with this problem. I'll update this post if the problem reemerges, but hoping that this fixes the problem permanently. I would encourage Netgear to consider adding this solution to your support page for this problem: https://kb.netgear.com/23352/A6200-A6210-WNDA3100v2-wireless-adapter-intermittently-disconnects
Good luck!
- Blanca_ONETGEAR Employee Retired
Hi Mekroval,
Welcome to NETGEAR Community!
Thank you for sharing these steps on what resolved the issue. This will benefit others who might turn up with the same issue. Kindly report back if you encounter any other issues.
Blanca
Community Team - fire_kid2003Aspirant
HI
where have you changed the value "Max USB Speed value from "USB Auto" to "USB 3.0" ?
on windows 10
- leeR17Initiate
Hi, I had the same problem for months here is how to change the USB Max value as suggested as a solution:-
1. Go to device manager
2. Expand "Network Adapters"
3. Double Click "NETGEAR A2610 WiFi USB3.0 Adapter"
4. Click Advanced Tab
5. Click Max USB Speed
6. Change Value on right from USB Auto to USB 3.0
 - thebrokebassistInitiateThank you for your solution. Appears to have worked for me. I nearly scrapped mine as well.
- JamnutzAspirantWell that solution didn't work for me because I've already done that and nothing has worked at all I'm about to scrap this thing because it's garbage I'm running Windows 11 which for some reason it's incompatible with but it works sometimes and it's been working and then also it doesn't work so obviously it's capable of working you guys just haven't made the drivers or whatever for Windows 11 either way I'm about to scrap this thing and never by Netgear stuff again trash
- larooshInitiate
Wenesday, June 5th, 2024 -- Possible solution
I've been dealing with this issue for a couple of days and I think I've found a couple of ways to fix it. I haven't had any disconnections in the past few days since I tried these solutions.First Method:
1. Go to Device Manager.
2. Click on "Network adapters".
3. Right-click on your network adapter and select "Properties".
4. Go to the "Advanced" tab.
5. Find "Max USB Speed" in the list of properties.
6. From the dropdown menu on the right, select "USB 3.0".
7. Make sure your device is plugged into a USB 3.0 slot.
8. Check in "Bluetooth & other devices" in Windows settings to see if it says "Connect to USB
3.0".Second Method:
1. Press the Windows key and type "Services".
2. Right-click on "Services" and select "Run as administrator".
3. In the Services window, scroll or press 'n' on your keyboard to find "NetgearSwitchUSB".
4. Right-click on "NetgearSwitchUSB" and select "Properties".
5. In the "General" tab, find "Startup type" in the dropdown menu and select "Disabled".
6. Click "Apply" and then "OK".Whenever I use my computer for the day, I turn it on and connect it with the Netgear Genei software.
Once it's connected, I restart my computer and it doesn't disconnect for the whole day.
I hope these steps help fix the issue for everyone.
