AR_UK1991
Nov 21, 2016Follower
A6210 wifi adapter channel connection
Hello,
I've recently installed an A6210 wireless usb adapter. I have no troubles connecting to the channels on AC wireless mode, however they offer a weaker signal strength to the N channels. The weaker signal is noticeable when playing games or streaming - I experience a lag spike every couple of minutes, very annoying!
I'm trying to connect to the N channels, using the netgear genie software, to compare speeds and general connectivity. After I type in the password and hit connect, it disconnects me from the AC channel but then just reconnects again on the same one. Is there a way to override this so I can connect to the N channels?
Does any of the above make sense? I am a networking noob, apologies.
The modem/router I am trying to connect to is a TalkTalk Huawei HG633.
Thanks
Alex
Hi AR_UK1991,
You may remove the network under your preferred networks.
JamesGL
Community Team
- JamesGLNETGEAR Employee Retired
Hi AR_UK1991,
JamesGL
Community Team - JamesGLNETGEAR Employee Retired
Hi AR_UK1991,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
