Myatt94
Dec 28, 2015Follower
A6210 Wireless Adapter Keeps Disconnecting
My A6210 adaptor keeps disconnecting. I am running windows 10, have installed the latest drivers, disabled the "allow windows to turn off adaptor to save power" option and used windows diagnostics to...
Diggo
Jan 13, 2016Tutor
Hi James
Thanks for responding
I understand U2 Mode is an issue - that wasnt my question. My question was "what is U2 Mode?"
Is it specific to Windows 10? (I'm using Win 7) and is that the reason I cant find the setting parameter?
Is it an abbreviation of USB 2.0?
JamesGL
Jan 26, 2016NETGEAR Employee Retired
Hi Diggo,
Let me check on it and I will get back to you.
