termin8or
Sep 26, 2016Aspirant
A6210 Wireless Adapter update download crashed.
Installed adapter via the included cd and worked fine. Went to download an update. Update crashed and apparently messed up the software. Cannot connect to internet. Tried reloading from cd but get "...
VE6CGX
Sep 26, 2016Master
Uninstall the driver and reinstall it.
termin8or
Tried uninstall, will not work. How then do I uninstall the driver?
- termin8orSep 28, 2016Aspirant
Hello, Is anybody out there. Been two days and nobody has answered!
- VE6CGXSep 28, 2016Master
What did you do to uninstall? Doing it from device manager?
- termin8orSep 29, 2016Aspirant
Tried uninstall using device manager as well as using the supplied cd. Either way it seems it goes to the same program. Don't know any other way to try.
- VE6CGXSep 29, 2016Master
Download driver manually. Delete the adapter from device manager. Unplug the adapter. Start over as if you are installing it first time. When asked to plug in the adapter do it finsh installing. Manually update driver thru device manager. Tried this?
If it does not work, you can eve go into registry and delete anything to do with the adapter.
