Bocchiere
Jul 16, 2018Aspirant
A7000 driver error
So I cannot update my drivers (code 28 drivers are not installed). I have windows 10. I tried running the automatic update but it cannot find it for the router. I tried restarting the computer this d...
- Jul 21, 2018
Dont install 15 it is having issue with windows
try the earlier 11 version it works fine.
schumaku
Jul 16, 2018Guru - Experienced User
This is not a Router, it's a WiFi Adapter with a dedicated forum section, this is why a moderator has moved your post (it just disappeared from the other forum section while I was replying).
Open the Windows 10 Control Panel ... go to System ... Device Manager ... to the Network adapters ... select the A7000 one (I?ve none- this showing an Inhell one here) ...goto it's Properties ... Drivers ... and use the [Uninstall Device (Advanced)].
Reboot the Windows 10 system, and retry the driver installation.
Bocchiere
Sorry I mispoke. I've tried that already, following those steps and then restarting the computer, and it did not fix the problem. I go back into Device Manager and the A7000 still does not have drivers installed and searching automatically does not turn anything up. I tried doing it manually and selecting the folder I extracted the most recent software update too, but that does not work either. I got that download here. https://www.netgear.com/support/product/A7000.aspx#Software%20Version%201.0.0.15%20(Windows)
It runs and completes but there is no change.
