Bocchiere
Jul 16, 2018Aspirant
A7000 driver error
So I cannot update my drivers (code 28 drivers are not installed). I have windows 10. I tried running the automatic update but it cannot find it for the router. I tried restarting the computer this d...
- Jul 21, 2018
Dont install 15 it is having issue with windows
try the earlier 11 version it works fine.
Bocchiere
Sorry I mispoke. I've tried that already, following those steps and then restarting the computer, and it did not fix the problem. I go back into Device Manager and the A7000 still does not have drivers installed and searching automatically does not turn anything up. I tried doing it manually and selecting the folder I extracted the most recent software update too, but that does not work either. I got that download here. https://www.netgear.com/support/product/A7000.aspx#Software%20Version%201.0.0.15%20(Windows)
It runs and completes but there is no change.
