Nboj
Jan 22, 2020Follower
A7000 drivers won't install on Mac OS "The package is trying to install content to the system..."
I'm running mac os 10.15.2 and when trying to install the drivers for the A7000 wifi adapter, It said "The package is trying to install content to the system volume. Contact the software manufacturer...
- Jan 23, 2020
Netgear says it is working on this issue. It is anyone's guess as to when it might happen.
Solved: Re: compatibility macos catalina - NETGEAR Communities
There is a workaround linked from that discussion.
Jan 22, 2020Guru - Experienced User
Right now the support for mac is at version 10.13----high siera. There's not a new driver for it.
If you check the mac download release notes, it'll show the updates.
https://kb.netgear.com/000058268/A7000-Software-Version-1-0-0-9-Mac
michaelkenward
Jan 23, 2020Guru - Experienced User
