vsyd
Apr 11, 2018Guide
A7000 speed issues
Hi.. i have the Nighhawk AC1900 wifi usb adapter (a7000) and I have a R7000 Nighhawk router. i have it setup on a tested usb 3 port.. but it seems to be limiting he speed to about 256Mbit (32MB) ...
vsyd
Apr 19, 2018Guide
I got the idea by seeing people with same setup on youtube getting nearly their max gigabit fibre fiber internet connections speeds.. anything better to add like if something could be causing it to max put at usb2 speeds
Hoser13
Apr 23, 2018Tutor
Same issue here, even sitting next to the router. Cannot get faster than 240 Mbps on a Gigabit service. Something has to be wrong here.
- Hoser13Apr 23, 2018Tutor
Did some troubleshooting. Check your router to see if WMM is disabled under the QoS settings. Mine was disabled. I re-enabled and speeds jumped remarkably.
