TurboVin
Apr 04, 2026Aspirant
A7500 recurring BSOD when used as Hyper-V virtual switch — WinDbg points to mtkwl6eux.sys
Experiencing recurring BSODs with my A7500 when configured as a Hyper-V external virtual switch on Windows 11 24H2. 4 crashes in 6 days. The adapter works fine in normal (non-Hyper-V) usage. Rep...
Apr 04, 2026Guru - Experienced User
Doing a search online with mtkwl6eux.sys seems to turn up alot of results of others seeing this issue for that file.
Might have a look as see if anyone has resolved this if the V Switch is enabled. If not you may need to not use it with this particular adapter.
