not listed
3 TopicsAC1900 Wifi Adapter internet cutting out for a few seconds.
Hi All, I recently built a new PC, and for the most part I haven't had too many issues. I installed my old wifi adapter to my new PC since I figured my AC1900 would have better throughput than the stock wifi adapter that came with my motherboard. However, right after install I get this issue where my internet will cut out for 1-2 seconds at most (not enough to disconnect me from online games from what I can tell), and then it will re-establish connection. I can also see this issue manifest when I'm in discord and have video going and I can see people's audio and video will stop for 1-3 seconds, and then continue. This occurs fairly frequently (several (5+?) times per hour), and I can see the blue triangle on the wifi adapter itself start blinking, and then it goes solid once again once it re-establishes a connection. Any advice or debugging steps would be greatly appreciated.480Views0likes7CommentsConnection stability issues Nighthawk AX1800 USB Adapter
Hi, I from France and just bought an adapter USB the Nighthawk AX1800 WIFI USB (A7500) . I constantly encounter problems with my connection. My wifi is very slow especially in games. I tought it could came from my router but there is no problem with my phone, ipad or TV. I start thinking that my adapter might be defective. anyone have a solution ? thx Nico427Views0likes3Comments
