nicoco29
Dec 13, 2025Initiate
Connection stability issues Nighthawk AX1800 USB Adapter
Hi,
I from France and just bought an adapter USB the Nighthawk AX1800 WIFI USB (A7500) . I constantly encounter problems with my connection. My wifi is very slow especially in games. I tought it could came from my router but there is no problem with my phone, ipad or TV. I start thinking that my adapter might be defective.
anyone have a solution ?
thx
Nico
What router are you connected to?
What band are you connected to? The 2.4ghz or 5ghz? (hint, make sure its on the 5ghz, 2.4ghz is a slow network sensitive to interference)
How far from the router are you?
Whats between the router and the device with the A7500? (brick walls, appliances, etc. ) Certain materials block wifi extremely well, so it's important to know what's between the 2.
- nicoco29Initiate
it’s my main router. Yes 5ghz. I am only 5 meters next to my router. There is no wall/door, only my sofa.
Ok but what router is it? Model?
I'm not saying this is you but we see a surprising amount of people with old Wireless N or AC systems that are basic devices who then buy a "new/high speed" adapter and don't understand why its slow or has issues.
Also, what 5ghz channels is the router set on?
What speeds do you get with a speedtest?
What speeds do you pay for?
What speeds do you get from a hardwired devices connected to the router?
