TurboVin
Apr 04, 2026Aspirant
A7500 recurring BSOD when used as Hyper-V virtual switch — WinDbg points to mtkwl6eux.sys
Experiencing recurring BSODs with my A7500 when configured as a Hyper-V external virtual switch on Windows 11 24H2. 4 crashes in 6 days. The adapter works fine in normal (non-Hyper-V) usage. Rep...
Apr 04, 2026Guru - Experienced User
Doing a search online with mtkwl6eux.sys seems to turn up alot of results of others seeing this issue for that file.
Might have a look as see if anyone has resolved this if the V Switch is enabled. If not you may need to not use it with this particular adapter.
TurboVin
Apr 11, 2026Aspirant
What's the likelihood Netgear reads these and decides to fix it? Or am I better off playing the lottery
