sadandfrustrate's avatar
Jan 08, 2019
Absolute nightmare, please help
Bought the N300 Wifi USB Mini Adapter and have had nothing but issues with it. I can not get it to connect solid to the internet for more than 30 secs at most.  It has connected to the modem but it does nothing online.  I have tried everything from using different USB ports.  Installing and uninstalling the driver.  Using the Drivers setup wizard.  Installing in manually. Restarting the PC.  Nothing wants to make it work properly.
It will talk tot he modem as I said, then it will connect for 5 seconds at the very most.  Then it will say connected with no internet, before going back to connected and secured, however even when it is connected and secured it will not do anything online.  I just get `No internet`errors on microsoft edge and chrome.
Wifi signal strength is showing as full strength and strong.  I have tried following the trouble shooting guide here on the Netgear site and made sure I was using the most up to date drivers.
Someone please help me before this gives me a stroke.  Also I am running on windows 10
  • Turns out these units ONLY work in USB 2slots.  Just a warning for others who seem to find no other solution to their connection issues.  I could not find this out anywhere officially, but there you go.  I previously tried other USB ports but out of all of them on my PC I only have two USB 2 ports and it works fine on those two! :)
    • michaelkenward's avatar
      michaelkenward
      Must be device specific. My A6100 adaptor works in a USB3 port, even though the Data Sheet says USB 2.0. The data sheet for the WNA3100M also says "Available USB 1.1 or USB  2.0  slot".
      Maybe there are chipset driver updates for your motherboard that fix the USB3 issue. Windows update will not find those. You need to hunt down the motherboard maker's site, or whoever made the PC and see if there are updates.
