wiww's avatar
wiww
Follower
Jun 01, 2015
AC1200 can't see any networks
Windows 7. New AC1200. Did the standard installation, also tried just installing the standalone driver (after uninstalling). Same result: Wireless adaptor claims to have correct drivers, but can see no networks.
Windows Diagnostics, give this error:
Windows couldn't automatically bind the IP protocol stack to the network adapter.
ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : A-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 50-46-5D-A7-32-D2
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::4898:133:62a3:82d5%11(Preferred)
Default Gateway . . . . . . . . . :
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{9F94BCF1-D976-4A93-9D2D-6AB1F151AC4D}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Any ideas?
1 Reply
  • To isolate the problem, try to install the adapter on a different computer or run your computer on safe mode with networking and install the adapter.
