supalova
Aug 07, 2018Aspirant
AC1200 wifi adapter USB 3.0 not working
Hi,
I buyed an AC1200 wifi USB adapter.
I tried to follow the installation procedure and it is not working properly when using a USB 3.0 port: "the device is not found" or something similar. At t...
michaelkenward
Aug 08, 2018Guru - Experienced User
Timber7777
Aug 23, 2018Aspirant
Sorry not a computer guy at all but I have the same problem but I only have WiFi now and had DSL , so how do I fix the problem with no way to down load till the ac1200 is running?
- michaelkenwardAug 24, 2018Guru - Experienced User
What have you tried?
Some people find that they do not need to download anything to get their wifi USB adapter to work. They happily use the drivers that are packaged in their version of Windows.
If you want to download the software, you do not have to do this on the same PC. You can download the file and copy it to your system with a USB memory stick.
