Mark975
Aug 02, 2015Follower
AC1200 Working With Windows 10?
As the titles says I want to know if my AC1200 High gain WiFi USB Adapter Dual Band USB 3.0 will work if I upgrade my computer to Windows 10. Help would be great. Thanks.
nhann
Aug 04, 2015NETGEAR Employee Retired
Hi Mark975,
Can you please confirm that you are using the A6210? If so, then your WiFi adapter should work with Windows 10. Please refer to the NETGEAR Support page for Windows 10.
Let us know if you need any further assistance.
NhanN
musicjunkie
Dec 11, 2015Aspirant
No matter what I try i cannot get the AC1200 to work with windows 10. After having to copy the whole CD to my hard drive before getting that to work, now it just comes up with no adapter found, i've tried it in various usb ports also. It works in my laptop windows 8 but not my PC any help please?
- musicjunkieDec 11, 2015Aspirant
Sorry it says the netgear a6210 adapter is not found.
- nhannDec 11, 2015NETGEAR Employee Retired
Hi musicjunkie,
Please download the latest software from the support page.
A6210 - http://support.netgear.com/product/A6210
Then follow these steps:
1. Open Device Manager by clicking the Start button Picture of the Start button, clicking Control Panel, clicking System and Security, and then, under System, clicking Device Manager.
2. Uninstall the old NTGR software and install the software downloaded from NTGR website again.Please DO run the NTGR software setup.exe first and follow on-screen instruction to insert USB adapter later.Please DO NOT insert the adapter first, then run the setup.exe.
