bamedlin
Dec 20, 2017Aspirant
AC1900 only getting 54mbps connection to router
I have an AC1900 usb 3.0 adapter and an R9000 router. The two devices are only getting a 54 mbps connection. Support had me change my security mode, even though it was already WPA2, and flip through various channels on the router. Nothing helped. Is there anything else I can try?
1 Reply
- Did you disable WMM? If so, then turn it back on. Without WMM, speeds will be limited to 54 Mbps.
