aalexandrebeta
Jan 24, 2017Master
AC5300 adapter ETA
What is the ETA of such a device? I do really don't know why people is purchasing SSD able to write and read more than 400Mo/s if they only have a crappy wifi inboard crapp able to perform max 10Mo/...
TheEther
Jan 24, 2017Guru
It doesn't really make sense to build an AC5300 adapter. That would be a tri-band adapter. Unlike routers, Wi-Fi adapters use only one band at a time. They'll connect either at 2.4 GHz or 5 GHz, not simultaneously.
The fastest 802.11ac adapter that makes sense to build would be a dual-band, 4x4 stream adapter, like the one below. It's an AC3100 class adapter (2100 Mbps at 5 GHz or 1000 Mbps at 2.4 GHz). You need a 4x4 stream router, also.
aalexandrebeta
Jan 24, 2017Master
I have a R8500 so not a problem.
An AC 5300 adapter would be great to use MIMO in order to bond channels and bandwidth!
