jszima
Jul 15, 2017Aspirant
AC6210 has to reinstall everytime I open my laptop
Need help keeping this adapter installed. Everything seems to work just fine when it is installed, except when I open my laptop back up, the USB plug and play detection goes through it's process o...
- Jul 17, 2017
Hi jszima,
Uninstall the driver and try to use the driver below.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36
JamesGL
Jul 17, 2017NETGEAR Employee Retired
Hi jszima,
- jszimaJul 18, 2017Aspirant
Thanks! That seems to have done the trick.
That was the driver that I had installed but I'm guessing the uninstall/reinstall is what did the trick.
Another benefit is that I'm connecting at a steady 866.5Mbps now. Before it went up and down from about 550 to 720.
Again, thank you for the help.
- JamesGLJul 25, 2017NETGEAR Employee Retired
Hi jszima,
You are welcome.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Das1996Aug 15, 2017Initiate
Any updates to the driver for this device?
I'm having similar issues when ever the pc (windows 10 64bit) comes out of sleep. Driver for A6210 gets reinstalled again. Also strange wifi connection. Once driver installation has completed, adapter connects to the access point for a second or two, drops connection then reconnects. Finally after al this, the connect is solid. All power management for the a6210 is disabled in device manager.
Is there a newer beta driver for this device? I didn't see anything from mediatek.
Edit: I should add, this is the only device that exhibits this type of device manager and connectivity behavior.
- jszimaAug 16, 2017AspirantNot sure if there is a new driver yet but I encourage you to uninstall and try the one above as it worked for me.
