CorbinGallion's avatar
Jan 16, 2023
AC7000 genie wont start
I downloaded the A7000_V1.0.0.15_Windows file to install the genie so the genie will give me the program yeah well I installed it and waited for the genie to open so i could start the setup and it wasnt opening I uninstalled it then reinstalled it still nothing idk if im dumb or something i really need help
  • plemans's avatar
    I usually use the stand alone driver and just let windows manage the wireless connection setup. Have you tried that?
    • michaelkenward's avatar
      michaelkenward
      I'm guessing here, but I think that plemans is referring to the "SA" program mentioned in the release notes:
      A7000 Software Version 1.0.0.15 (Windows) | Answer | NETGEAR Support
      You will find that the zip file contains two exe files.
      Try A7000_Windows_Standalone_V1.0.0.15.exe
      Or see if the native drivers in Windows will work.
