Maltire
Mar 27, 2017Aspirant
Adaptater compatible with windows 10 ?
Hi everybody I would like to know which wifi adaptater are compatible with windows 10 because some are compatible with windows 10 but it's not writen in the description of the adaptater.
- Mar 30, 2017
Hi Maltire,
You can check the A6210 adapter and use the driver below.
https://kb.netgear.com/000037991/A6210-Software-Version-1-0-0-36?cid=wmt_netgear_organic
JamesGL
Mar 30, 2017NETGEAR Employee Retired
Hi Maltire,
