RV11
Oct 22, 2016Tutor
Adapter A6210 not detected
Was not having any issues at all with my A6210 using Windows 10 until Thursday evening, 10/20, when I updated my software version to number 35. Now, the genie on installation will not detect the ada...
steveath
Oct 23, 2016Guide
Same issue here. A6210 not detected since software update 35. Even reinstalling the original driver from cd does not help.
TorrendotTaxes
Oct 23, 2016Aspirant
Having the exact same issue since trying to install the .35 update; my a6210 adapter is failing detection. I've uninstalled the netgear genie to try a reinstall but no luck so far.
- Angus66Oct 24, 2016Aspirant
I'm having the same problem as everyone else - my A6210 adapter isn't recognized by the latest Netgear software. Uninstall/reinstall/etc doesn't fix the problem.
Only (temporary) solution is to just uninstall everything, restart and let Windows 10 install the driver from 04/21/15.
Is Netgear addressing this problem???
