RV11
Oct 22, 2016Tutor
Adapter A6210 not detected
Was not having any issues at all with my A6210 using Windows 10 until Thursday evening, 10/20, when I updated my software version to number 35. Now, the genie on installation will not detect the ada...
billcoghlan
Nov 18, 2016Aspirant
Solution!!
Try this -
1. Install v35
2. Stop the istallation at the point where you would hit next to detect the device
3. Plug it in to your USB
4a. This is the step that fixes it -> https://kb.netgear.com/app/answers/detail/a_id/30146
4b. From Device Manager / Network Adapters choose scan for hardware changes
5a Hopefully this should find "USB"
5b Right click on USB and then choose detect / scan for new (not sure what the actual description was
5c There are some prompet to follow but this is where Windows finds the USB driver to discover the A6210 via the USB.
Angus66
Nov 20, 2016Aspirant
I followed those steps from the link you provided (thanks for that BTW) and everything looked good - it found the A6210 USB, picked the adapter, pointed it to the folder where the new driver is and installed.
When I right-click on the adapter in device manager the driver listed is still listed from 4/21/15 & it still lists it as a "802.11ac Wireless LAN card.
