RV11
Oct 22, 2016Tutor
Adapter A6210 not detected
Was not having any issues at all with my A6210 using Windows 10 until Thursday evening, 10/20, when I updated my software version to number 35. Now, the genie on installation will not detect the ada...
marcwx
Nov 20, 2016Aspirant
ANYONE WHO STILL NEEDS HELP; just reiterating what someone said here.
1. Click "Install Windows Standalone Driver", should download successfully.
2. After search and bring up settings in Windows 10
3. Go to "Network & Internet"
4. Go to "Wifi"
5. Have the Netgear Wifi Enabled (could be titled Wifi-2 if you have another wifi card) and the other one disabled (if you have another wifi card)
6. Click "Show Available Networks"
7. If on Windows 10, it should bring up the list of wifi connections in bottom right. Make sure you are on the tab of the Netgear Wifi you would've typically used
8. Select the connection and enter your password, should connect and your problems fixed!
