RV11
Oct 22, 2016Tutor
Adapter A6210 not detected
Was not having any issues at all with my A6210 using Windows 10 until Thursday evening, 10/20, when I updated my software version to number 35. Now, the genie on installation will not detect the ada...
JamesGL
Apr 13, 2017NETGEAR Employee Retired
Hi steveath,
Try to disable the power saving mode of the adapter.
https://kb.netgear.com/20940/Fix-wake-up-issues-for-USB-wireless-adapters
JamesGL
Apr 23, 2017NETGEAR Employee Retired
Hi steveath,
Any update if it resolves your issue?
- steveathApr 24, 2017Guide
I disabled the power saving as suggested. The adaptor still disconnects when my pc goes into sleep mode (Should it do this?), but so far it reconnects without me having to unplug etc. I'll give it a few more days, but if nothing changes then I think it should be ok.
- JamesGLApr 25, 2017NETGEAR Employee Retired
Hi steveath,
It is normal since no activity when the PC is on sleep mode.
- steveathApr 26, 2017Guide
If that's the case and as the adaptor is re-connecting after "sleep" then I am pleased to say that all is now ok. Thanks for your help JamesGL
- JamesGLApr 27, 2017NETGEAR Employee Retired
Hi steveath,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- steveathApr 28, 2017Guide
Hi
Not sure if I have added "Accepted Solution" correctly / I have used add a tag. Please let me know if there is another method.
