RV11
Oct 22, 2016Tutor
Adapter A6210 not detected
Was not having any issues at all with my A6210 using Windows 10 until Thursday evening, 10/20, when I updated my software version to number 35. Now, the genie on installation will not detect the ada...
JamesGL
Apr 28, 2017NETGEAR Employee Retired
Hi steveath,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
steveath
Apr 28, 2017Guide
Hi
Not sure if I have added "Accepted Solution" correctly / I have used add a tag. Please let me know if there is another method.
