Jencarna's avatar
Jencarna
Novice
Mar 26, 2015
Adapter keeps connecting and disconnecting
I use my adapter to connect to the school's internet (our school now requires us to connect to the internet) and this morning I encountered a problem.
I'm looking at my internet connections right now and my network adapter keeps disappearing and reappearing every 3 seconds
I am also looking at device manager and each time it disconnects device manager refreshes and NETGEAR A6100 WiFi Adapter still remains, and only disappears if I physically take the USB out.
It was working perfectly before and I can't think of anything that may of caused this. I normally just take it out of my computer after each lesson and put it in a small plastic bag, safe from harm.
I have tried updating it and I am using an ASUS F550WA 15inch touchscreen notebook. Any suggestions is greatly appreciated.
1 Reply
  • Retired_Member's avatar
    Retired_Member
    I would un-install it and delete all drivers and associated adapter program. Then reboot and reinstall. If same problem again I would suspect the adapter has failed, test on another device and check for driver updates.
