shawner123
Feb 24, 2017Follower
Best usb adapter for Nighthawk ac1900 r7000 Smart Wifi Router
Hello, I just purchased the Nighthawk ac1900 r7000 Smart Wifi Router, it seems to work alright with most of my existing devices which are all 802N, but I would like to upgrade the USB wifi adapter...
- Feb 27, 2017
Hi shawner123,
Our latest AC adapter is A6210. You can check the support site for the technical specification.
