Tafman
Aug 07, 2015Follower
Big Problem with NetGear WNA3100
Net ger WNA3100m wireless adaptor Windows 10 not found.
A friend of mine installed Windows 10 on a new drive in his windows 7 system everything worked Ok except for the Net gear WNA3100m wirele...
jmerritt
Aug 16, 2015Initiate
I recently installed Windows 10 and have the problem with the Netgear WNA3100 dropping the connection. I went to the Netgear site and downloaded the software for Windows 10 but am still having the problem. I followed the directions for uninstalling the Netgear software and then reinstalling as directed. If there is something else that I am missing I would appreciate any help to this problem. I am at the point of replacing the WNA3100 if I can't solve this problem.
JamesGL
Aug 18, 2015NETGEAR Employee Retired
Hi jmerritt,
Try to install the driver of the adapter manually.
1. Install the USB driver version 2.2.0.4 (Supports Win10).
2. Once installed manually update driver software. Open Device Manager , select the WNA3100, right click , select Update Driver Software.
3. Choose Browse my computer for driver software
4. Choose Let me Pick from a list of device drivers on my computer
5. Select the one with NETGEAR INc.
JamesGL
Community Team
- jmerrittAug 19, 2015Initiate
JamesGL thank you for the reply. I solved the problem. When I was running Windows 7 I received a message about being able to speed up the Netgear adapter by plugging it into a USB 3.0 port. I moved the adapter to a USB 2.0 port and everything is working fine. I guess I am giving up some speed but for the reliability I am OK with this. When I reviewed the specs for the adapter it didn't say anything about 3.0 but it worked well in Windows 7. I wonder why Windows 10 doesn't likethe 3.0 port.
