Mugsy101
Feb 29, 2016Aspirant
BSOD Driver_Page_Fault_In_Freed_Special_Pool (bcmwlhigh664.sysDriver_Page_Fault_In_Freed_Specil_Pool
My wnda3100 v2 is now creating an error and BSOD Driver_Page_Fault_In_Freed_Special_Pool (bcmwlhigh664.sys) I am running w-10 since 8/2015, I have had the adpter for sral years with no problems...
JamesGL
Mar 07, 2016NETGEAR Employee Retired
Hi Mugsy101,
Is the driver used for WNDA3100v2 is for Windows 10?
http://downloadcenter.netgear.com/en/product/WNDA3100v2#searchResults
Mugsy101
Mar 08, 2016Aspirant
Yes, it was updated.
- JamesGLMar 15, 2016NETGEAR Employee Retired
Hi Mugsy101,
You may need to clean the registry of your computer. Also try to install the adapter on a different Windows 10 computer. When installing, use the standalone driver instead of the driver with Genie.
- Mugsy101Mar 21, 2016Aspirant
I have cleaned the registry, and I'm not sure why you want me to install the driver on another dindows 10 machine. Everytime I plug in my network adapter I get the BSOD.....so basically nothing has changed and nothing is fixed regardless of how many suggestions I get from here or from microsoft, or anywhere.
- JamesGLMar 29, 2016NETGEAR Employee Retired
Hi Mugsy101,
Have you tried disabling the Norton just to isolate the problem for BSOD?
