jonilo5's avatar
jonilo5
BSOD issue Win 8.1 64 bit WNA3100
I get alot of BSOD, and I suppect it can be my WNA3100, but I have Windows 8.1.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi jonilo5,
    When WNA3100 is uninstalled on your computer, do you still get BSOD?
    JamesGL
    Community Team
    • jonilo5's avatar
      jonilo5
      Is there any update, beta or patch to the driver?
      I think it is this driver making BSOD. (WNA3100_V2.2.0.2)
      • JamesGL's avatar
        JamesGL
        Hi jonilo5,
        Can you uninstall the drivers in your computer then reinstall it?
        JamesGL
        Community Team
    • jonilo5's avatar
      jonilo5
      I am not sure, but sometimes when I get BSOD the WNA3100 has a constant light (blue) - even when the computer is off. To fix it I have to remove it from the USB and but it in an other Usb-port.
      Not sure what this will tell (the lastest BSOD I got) :
      This was probably caused by the following module: scmndisp.sys (scmndisp+0x16D1)
      Error: IRQL_NOT_LESS_OR_EQUAL
      file path: C:\Windows\system32\drivers\scmndisp.sys
      product: ® Neutral Wireless Solution
      company: Windows (R) Codename Longhorn DDK provider
      description: NDIS User mode I/O Driver
      A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: scmndisp.sys (NDIS User mode I/O Driver, Windows (R) Codename Longhorn DDK provider).
      Google query: Windows (R) Codename Longhorn DDK provider IRQL_NOT_LESS_OR_EQUAL
      Thanks for the reply! :)
