AuntBAM
Aug 06, 2016Aspirant
Cannont connect Panasonic TV through Netgear wireless Adapter to Netgear router
Panasonic Smart TV with Viera, Model: TC-L47E5 Netgear Wireless Adapter, Netgear substitue for Panasonic Model #: DY-WL10 Netgear Router, (WNDR4500v2) working already with other wireless devices in...
JamesGL
Aug 21, 2016NETGEAR Employee Retired
Hi AuntBAM,,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
AuntBAM
Aug 24, 2016Aspirant
Hi! No, I still have not been able to resolve the problem. The Smart TV does not recognize that there is an adapter. I tried the instructions that you referred to and when the adapter is plugged into the USB Port on the back/side of the TV, and I go to Network, Wireless Network it shows on the TV, "Compatible wireless adapter not found. Please insert adapter into the TV's USB port and try again.
Can't get any further into the Wireless Setup as it does not see the adapter at all. Any other ideas? Thanks, Bridget
- VE6CGXAug 24, 2016Master
Smart TV set supposes to have built-in WiFi card already. How come you are plugging in the adapter to the USB port? Adapter needs driver to function. How are you going to install driver on the TV? What's wrong with built-in WiFi card?
- JamesGLAug 28, 2016NETGEAR Employee Retired
Hi AuntBAM,,
Check the link I have provided. Check the list of the TV that it is compatible and also check the Serial number of your WNDA3100v2 is the one the supports the Viera TV.
JamesGL
Community Team
- AuntBAMOct 05, 2016Aspirant
Just found out today that the Panasonic TV is not recognizing wireless anymore. Connected it with an Ethernet Cable and it now works. Doesn't even need the adapter. Yikes! Not sure if a storm or something destroyed something internally in the TV. Lots of time spent to determine it is the internal workings (or not) of the TV.
Thanks all for the help!
